Does anyone know where I can get a new set of bolts? Im talking about the bolts that mount the oil pan to the block. Id like a new set but I either don't know what Im looking for or can't find anything.
Can anyone help?
Can anyone help?
I did that to the first one I lost and replaced it with a common bolt from Lowe's and when I torqued it down it snapped off. So Im kind of leary to use a common bolt.Just take one of the bolts to your local ACE Hardware or Home Depot and match them up. Simple as that! They're nothing special, just bolts. That's what I would do if I was in this situation.
Fixed it for youFYI, the torque spec on those oil pan bolts is 84 in/lbs according to the factory service manual (FSM). That converts to 7 ft/lbs.
That's hand tight. You shouldn't be torquing down those bolts at all, especially with a torque wrench. If you are, then that's why you're breaking the bolt heads off. Those bolts are small, they aren't mean to have any force applied to them.
Fixed it for you
Those bolts shouldn't be torqued down much at all. How much did your torque it down to?
I assure you, those oil pan bolts are nothing more than common bolts. They aren't Grade 8 bolts or anything, just regular bolts. Look for flange bolts if possible. My local ACE Hardware carries tons of flange bolts, and I can guarantee they would have them in this size. I think most ACE stores will.
I think I'll go by there and see if I can get a stronger grade bolt. I still have the job of fishing that broken bolt out though....ugh...not looking forward to it.Just take one of the bolts to your local ACE Hardware or Home Depot and match them up. Simple as that! They're nothing special, just bolts. That's what I would do if I was in this situation.
