Roof Rack Suggestions
BugoutJeep
KY
I hope I'm not beating a dead horse here, so I apologize if I missed this when searching.
I am thinking about getting a roof rack. I've had stuff like the Yakimas and stuff before, but I want something I can use to occasionally free up some space, but also as an elevated platform for scouting and for doing some long range target shooting. I haul kayaks and ladders from time to time. At some point I'd like to get a small hard top RTT, but would likely move this to a trailer once I can save up and get the time to build one.
I do want to occasionally pull the hard top like everyone else, but I typically do this only once or twice a year. Still I'd prefer to make this as easy as possible, but it'll have to be the frame type mounted rack with ladder.
Some background I'm working on running an ARB fridge inside the tub, I bought an 82 qt but after a few weeks of testing had to return it because it wouldn't/couldn't maintain any temperature and ARB said it wasn't working properly and it was used so warranty didn't apply. My plan is to normally go out with the big fridge and slider. When I get another fridge I'll run an AUX battery for the fridge, coms, lighting, and powering up devices. I would like to be able to store some of the smaller flexible 50W or 100W solar panels for times I'm in the field for longer stretches, especially in the summer. I don't intend to run those panels on the rack as I'm typically going shade for the vehicle when it's hot out. I may set panels out when I go to work and I'm too lazy to take the fridge out of the back of the Jeep. Typically the battery will be charged and isolated while driving or at idle.
I run an ARB awning, but at night I typically just go under the stars, tarp or if it's bad out a small backpacking tent. I've been using a hitch mount cargo carrier a lot lately, but I can't open the swing-out tire carrier very far as it hits, so no access to the fridge. I've drawn up some stuff on a more elaborate tub mount tire/cargo carrier to work with a tail gate, but I'm not sure it'll free up enough room and it won't do anything for an elevated position for scouting, etc.
Anyway I've been looking at the GOBI Stealth the most and I've seen some stuff by Garvin. I'm sure there's others. If you have any suggestions that would be great and I've thought plenty about just skipping the rack, but I keep adding all this cool off-road gear, so It's getting harder to put it everywhere.
Thanks
That was a good read for general camping, but didn't quite find much on roof racks. I was only saying a certain type of rtt may eventually find its way on top.
I may add that me wanting a rtt would have more to do with scouting for a long time where I would be watching for game and many fields around my area are grown up and only kind of flat where the elevated stance from a vehicle is useful.
This is off topic, but someone mentioned the tear drop and originally I wanted something like that but figured I could make the trailer more compact with a small rtt on top I could raise or lower for gear storage underneath. Typically the trailer would be my preferred method for hauling gear, wood, equipment parts, fluids, etc. Again I'm off topic because I don't know which direction I want to go with the trailer either.
Anyway does anyone have experience with the Gobi Stealth, garvin racks or others? I do keep my jeep in the garage and I've got about 6in or more of clearance from the hardtop. But I'd like to know how much a pita the hard top is to remove and how sturdy it will be for elevated shooting and scouting.
Thanks
I think I'm pretty settled on the Gobi Stealth rack for general purpose use. The accessories seem kinda pricey, so I'll probably just make those as I go and add them later.
If anyone has any experience, I'd be interested, even if I've already ordered it.
Thanks
I have the Garvin rack. Can hang axe, shovel and hilift off the side of it with the garvin brackets. I’ve been happy with it. It’s easy to remove by yourself like I did to install my hardtop. I mount my RTT on it and with 2 people sleeping it still feels very sturdy with the weight on the rack. No more than usual wind noise
The previous owner of my Jeep installed a Garvin Wilderness rack. It has hinges on the rear that allow you to remove the hard top without completely removing the rack. It bolts into the side of windshield in the front. In the rear, there are two mounts. One is drilled into the body near the seam between the body and the hard top. The other is hinged and connected to the body mount under the tub.
The rack is modular and is fairly easy to remove and store. Overall it seems to be well built.
I removed the rack and the arms since I wasn't using it, but I'm keeping it around in case I have the need.
The Garvin is what I originally was looking at, but felt the Gobi expanded metal on top would be a bit easier for just hopping up there with a shooting mat for a bit of practice. Or a place during a summer to quickly go to cool down once I find a nice cool area with a stream or something when we're doing work around the farm.
Currently I mount my hi-lift to my bumper and this won't change I think for quite some time. I will put my awning on the rack, a couple back-up lights, Maxtrax, probably not my Max Ax, but I'm going to get the toolbox and I'll try to put the Max Ax "tool kit" in the box with some straps, and as much as I can get to fit as possible. The accessories are too pricey for me but I do like the idea of the toolbox that's made for the rack. Everything else, I can order later, but there's so many ways to attach stuff to tubing that I'm not overly concerned.
Obviously if I go on a big trip I'll add a bunch of food/clothing, etc type gear. I'll probably get something for gasoline to put up there as well like Rotopax for use with some of our generators and 1 tractor we've got that uses it and the height may make filling a tractor much easier. I don't mind storing diesel inside the tub, but gas is too volatile for my preferences.
Reactions: TJDon
Any issues getting into garages?
(Off topic). Man I wish I had your doors! (Back on topic[emoji23])
The guy that framed in our garage door made it 3" shorter than it should have been. Luckily I still had about 1" of clearance between the top of the rack and the bottom of the garage door frame. My Jeep is sitting on 33s with a 3.5" lift.
My garage seems fine height wise, but wasn't sure if you ran into issues anywhere else. 1 of my trucks is very close to the top though, but it's so long that it won't fit well so I've never bothered pulling it in.
Well I think I'm going to go and order the Gobi though as I like the expanded metal, the round tubular frame and ladder. Pretty minor differences though. The girlfriend likes the Gobi and at these kind of prices and lead time, I don't want to wonder, what-if.
I can't really find anything negative on either, except hard to remove the hard top. I've taken the top of twice a year once and zero a couple of times. I have a soft top, but don't like it much.
Thanks
Reactions: TJDon
@DieselJeep Did you order the Gobi rack? Any updates on what you like/dislike about it? I am considering buying one primarily for a roof top tent. Adding one will mean my Jeep will no longer fit through my garage door so I'm also interested in knowing how easy/hard it is to install/remove the rack
I did order it and after 5 or 6 months it arrived. Order everything you think you may want in the future when you place the order and be prepared to wait.
I really like it but I haven't gotten to fully utilize it yet. I haven't removed mine, though I need to make adjustments. I'm pretty sure my mpg dropped too, but I got it around the time I was removing my doors.
I found the most difficulty in installing the front part of the rack, so if you've got to fully remove it, then maybe it's not the best accessory. I'm torn on RTTs I think I'd like to get one for a trailer and I lean toward the hard top varieties that you practically just hold down a button to open and close.
I do really like the rack, but I'm still in the afterglow to be 100% experienced in the issues.
