Hey all. Hopefully my first post will help someone out. I've gotten a ton of good info here!
I'll make a short story long: I am rebuilding my 2003 TJ, swapping out PO's parts with new. I swapped out the 4" lift springs, stock control arms with adjustable, removed TC lowering spacers, installed sye kit and cv driveshaft.
I spent most of a day adjusting control arms back and forth from + .5 degree to -2.5 degree, but just could not get rid of vibration. (It vibrated pretty bad over about 35 mph.) To make sure it was in fact the driveshaft, I removed the rear driveshaft and drove in 4 high. Vibration gone.
I found the specs for driveshaft run out (.020") in the service manual and checked the shaft. There was about .012" in the rear end of the shaft, and about .030" in the front end of the shaft.
I removed the double Cardin joint from the TC output yoke and rotated half a turn. When I was cleaning up the yoke, I noticed a burr that 'may' have kept the u-joint from seating properly, but I don't think so. Either way the runout after reinstallation was arout .010", and the vibration was gone.
Phew!
Phew!
