First off, this is my first post to this forum. I have been lurking and using all of the super helpful information on here and hope someone can give me a hand.
So, for Christmas I got some new audio equipment for my 2003 TJ. Some shit boss audio speakers to replace the front speakers and the pods in the back temporarily. My main concern was the factory subwoofer, as it seems is common, it was rotted to pieces.
I replaced the front speakers and rear pods with no issue. Two days ago, I wired the new aftermarket subwoofer up and had no issues. It worked great. It is the 1 Ohm Kicker model that has been posted on this forum and others which is supposedly great, don't know the exact model right now.
On an hour drive yesterday, the sub started cutting out intermittently, and it seemed like the other speakers may have gotten quieter too.
Hoped this might fix itself on the drive home, but no luck. Strangely enough, it seemed like when I went uphill, the sub would come back or if I took a tight turn. Cannot replicate this today.
Cut to today, and I install my new headunit hoping this would fix the issue. Headunit is installed, and everything is working fine other than the sub. I know the sub is wired correctly to the new headunit, because it cut in for a second during installation.
I took the whole console unit apart again and checked everything to make sure all my wires were in good shape, everything looks okay. Tested the leads to the sub with a multimeter, reads hot. Also took a small 6x9 I have lying around and hooked it up to make sure the sub wasn't bad, didn't play anything through the 6x9 either.
Unhooked the positive and negative of the battery, rehooked everything up, still no luck.
I have tried about everything I could think of and really need some help from all you gurus on this forum.
Thanks for taking the time to read and try and help.
