Borrowed from Feets at Moparts:
http://board.moparts.org/ubbthreads...hat-you-never-wanted-to-know.html#Post1235219
Some folks liked the numbers that came up in the brake thread. I've thrown the most common stuff out in the open. Now, an engineer would be kicking and screaming about this stuff but it's good enough to get an idea what's going on.
I'll try to keep it simple for those who don't care much for math. These calculations build on one another. It's kind of a step by step thing.
Get a pencil, some paper, and a simple calculator. I use the calculator included in Windows.
Click your start button > All Programs > Accessories > Calculator.
It will be helpful if you write down what the numbers mean. Instead of 7 try writing "pedal ratio = 7" so you will remember what each of the numbers mean.
For this example I will use a common brake setup. Nothing exotic here. 11.75" Cordoba rotors, 2.75" slider calipers, manual 15/16" master cylinder, and a typical brake pedal.
Measure the stuff on your car. Don't use my measurements.
PEDAL RATIO
Before you start with crazy math, go find your brake pedal ratio. Measure from the middle of the pedal pivot to the middle of the pad on the brake pedal. Now measure from the middle of the pivot to the middle of the master cylinder push rod pin.
Divide the total length by the push rod distance. That is your pedal ratio.
14" pedal? 2" to the MC pin? Ratio is 14/2 = 7.
7:1 pedal ratio. Write that down. You will need it later.
AREA OF A CIRCLE (PISTON)
The very first thing you need to do is remember how to find the area of a circle. Your circle can be the master cylinder piston or the brake caliper piston.
It's pretty easy.
Pi R squared
Yes, the pies mom made were round but in physics Pi R squared.
Pi = 3.14 (number goes on forever but this is good enough)
R = radius of the circle (half the width of the piston)
squared = radius times the same radius.
Have a 2.75" piston? The radius is 1.375" (half of 2.75).
So, 3.14 times 1.375 times 1.375
The area of the piston is 5.93". Feel free to call it 5.9 inches.
Wanna cheat? Click here:
http://www.calculateme.com/cArea/AreaOfCircle.htm
A note for people with multi-piston calipers: Only count the pistons on ONE side. Don't worry about why. Just count one side. It's the correct thing to do. Your numbers will be accurate and your headache will be smaller. Be sure to measure all the pistons on that side. They may be different sizes. Find the area of each piston on that one side. Once you do that, add the numbers together for a total area. Use that number for your caliper piston measurements.
Most master cylinders for our old cars are measured with fractions. Not good with fractions? Grab your calculator. Divide 1 by 16. Now you know 1/16 of an inch is .0625".
A 15/16 master cylinder is 15 times .0625 or .9375 of an inch. Plug that in to the above formula and the area of the master cylinder piston is .6902 square inches.
MASTER CYLINDER PRESSURE
Want to find the pressure made at the master cylinder?
You need the pedal ratio, the size of the master cylinder, and figure out how hard you want to push on the pedal.
I'm working with a
MANUAL master cylinder. Throw a booster (vacuum or hydro) in the equation and you're on your own.
Multiply the pressure you push on the pedal times your pedal ratio. Divide your answer by the surface area of the master cylinder piston.
Using the numbers above, the pedal ratio was 7:1 and the master cylinder was .6902". Let's stomp on the pedal with 100 lbs of push.
100 times 7 equals 700. Divide that by .6902. You get 1014 pounds of force.
EFFECTIVE RADIUS OF A ROTOR
To work with the actual braking ability you really need to find what is called the effective radius of your brake rotor. To do that you need to know the caliper piston diameter (only the biggest one for calipers with more than one piston) and the diameter of your rotor.
Effective radius is the total diameter of the brake rotor plus that same diameter AFTER you subtract the diameter of the piston. Then, divide by 4.
Use a "big" Mopar 11.75" rotor and the 2.75" caliper we used above.
11.75" minus the 2.75" piston is 9 inches.
So, 11.75" plus 9" is 20.75".
Divide by 4 and you get a 5.18" effective radius.
BRAKE TORQUE
Now we're ready to find out what stomping on the pedal does for us.
To find the actual brake torque (stopping force of the brakes) we need the master cylinder pressure, the caliper area, and the effective radius.
Multiply the line pressure by the caliper area.
Take that number and multiply by the effective radius.
The result is your brake torque.
Since we were measuring in inches we need to divide by 12 to make it ft/lbs.
Our line pressure was 1014.
The caliper area was 5.9.
The effective radius was 5.18.
1014 * 5.9 * 5.18 = 30989 in/lbs
30989 in/lbs divided by 12 = 2582 ft/lbs.
Guess what? That's only one side of the rotor. The calipers press on both sides of each rotor so double that number.
You can have 5164 ft/lbs of braking on each front wheel with 100 pounds of pedal effort.
That's serious stuff! Think your tires can handle it?
BRAKE PEDAL MOVEMENT VS BRAKE PAD MOVEMENT
To find out how far your brake pads actually move when you push your brake pedal you need the pedal ratio, the master cylinder area and the caliper piston area. We're going to assume you've already taken up all the slack in the pedal and push rod.
Divide your master cylinder area by the caliper piston area.
Divide that number by the pedal ratio.
Divide that number by the 4 front brake pads (2 pads on the left and 2 pads on the right).
.6902" master cylinder divided by the 5.9" caliper piston area gives you .1169".
.1169" Divided by the pedal ratio of 7 gives you .0167".
Dividing by 4 front brake pads gives you a total of .0041" of movement.
So, every time you move that brake pedal one inch the brake pads each move 4.1 thousandths of an inch.
Brake pads are generally a couple thousandths of an inch off the rotor so they can't move far. If they did your pedal would fall to the floor.
Clear as mud?
