Thoughts on this frame?
ciganluk
Jacksonville, FL
Good?
Reactions: Twopoint
That is a clean frame. Drop that transfer case skid and take care of that quick though. I put spacers (think transfer case drop spacer) after I removed the rust and painted. This helps keep moisture from being sandwiched in there. I'd touch up the small spots of rust and coat it with Eastwood or spray it with fluid film a couple times a year.
Looks good to me! A bit of surface rust in some places, but a wire wheel will take care of that.
Check out the inside with an endoscope of course.
Reactions: ciganluk
It looks great. It just has a few spots here and there, and overall just looks dusty. If you're really concerned, take a ball peen hammer and go around tapping it. If the metal makes a nice ping, its solid. I'd be very surprised if you found any spots with serious rust.
Reactions: ciganluk
Looks good to me too, If you drop the skid to wire wheel the rust make sure to support the transfer case.
I don't know what year that Jeep is but I have to ask:
Were those pictures taken when it was only about 6 months old? :unsure:
OK, I just went back and looked again. Maybe I should have asked:
Were those pictures taken when it was only about about one year old?
Reactions: DrDmoney
Some of the things you might want to check into are;
Where are the new brake lines due to recent service?
The same with new rubber hoses at transmission cooling lines to radiator.
What’s up with the blue silicone on the brand new drain plug on the oil pan?
Why is the tranny pan so clean? Or is that the wet look?
It otherwise looks pretty good underneath, what does the rest look like because we’re all dying to see?
78087
78088
78089
78090
78091
78092
78093
Reactions: ciganluk
View attachment 78087View attachment 78088View attachment 78089View attachment 78090View attachment 78091View attachment 78092View attachment 78093
Steering wheel?
https://dallas.craigslist.org/ndf/ctd/d/apo-2002-jeep-wrangler-1-owner/6816369103.html
Reactions: ciganluk
I asked about the tranny pan.
"tranny pan and oil pan clean, always clean off undercarriage when we first get them in. got dirty again after driving it around but pans still clean, was also recently resealed.
Oil drain plug was there when we got Jeep. does not leak from plug or anything.
Has extremely small oil leak if you let it sit a couple of days. More like a wheep. After a cpl of days there will be oil on the ground about size of dollar coin"
extremely small oil leak?:unsure:
The only thing I see, and this is completely OCD on my part, is that both the transmission pan and the transmission cooler lines have been recently replaced, cleaned or worked on. I'd just be sure it shits smoothly. A good owner or mechanic would have fixed those things so it's not an issue but at a dealer I'd treat it as a caution flag.
Reactions: ciganluk
