So I guess I have a 3 inch lift and need shorter shocks?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Ok well I'm not gonna be taking the springs out at the moment. I think I'll just try to find a replacement cross bar and extract the broken bolt.It's hard to say, those measurements are pretty close & I don't know how far in that shock strut can be pushed its body before it bottoms out. The standard way to tell is to remove the springs & fully cycle the axle so you can see if the shock bottoms out before the bump stops make contact. But the bump stops will often compress quite a bit under force, especially if you're still using the squishy factory bump stop. So it very well could be allowing the shocks to bottom out which will break stuff.
OMG those are some of the worst riding shocks around. Seriously, those have had a pretty horrific reputation for poor ride quality for many years.Looks like I have some Explorer ProComp ES3000 now.
So RS5000. Not RS500X. Got itOMG those are some of the worst riding shocks around. Seriously, those have had a pretty horrific reputation for poor ride quality for many years.
A good low cost set of replacement shocks that would ride and perform much better would be Rancho's fairly inexpensive RS5000x shocks. My previous superb OME NItrocharger shocks finally gave up the ghost after many hard miles & I replaced them with the then-new RS5000x. I was shocked how well they ride and perform, I am surprised they're so good that I don't miss my OMEs at all.
Don't confuse the newer RS5000x with the older RS5000 shocks which are as bad and stiff riding as your current ES-3000 shocks are.
Wow my brain is broken lolSo RS5000. Not RS500X. Got it
Uh I'm confused if you caught your error or not but it's the RS5000x you want.So RS5000. Not RS500X. Got it
Yes. The RS5000X I'm trying to find the right ones now. Thank youUh I'm confused if you caught your error or not but it's the RS5000x you want.
Have a 3 inch lift according to the measurements of the rear springsDo you know how much lift you have? If it's around 2" then I have shocks for sale in the for sale section. They are RS9000XL adjustable shocks.
