JayTJ Member Original poster Joined Mar 10, 2019 Messages 31 Location Alabama Apr 20, 2019 #1 1997 2.5 4 banger automatic Going to replace rear main seal. Can someone tell me what all I need besides the seal, oil pan gasket, oil, filter, transmission fluid, gasket? TIA
ScottyZ Member Joined Oct 1, 2018 Messages 98 Location Buffalo, NY Apr 20, 2019 #2 JayTJ said: 1997 2.5 4 banger automatic Going to replace rear main seal. Can someone tell me what all I need besides the seal, oil pan gasket, oil, filter, transmission fluid, gasket? TIA Click to expand... There's a write up on this forum. Look under the "how to" section.
ScottyZ Member Joined Oct 1, 2018 Messages 98 Location Buffalo, NY Apr 20, 2019 #3 JayTJ said: 1997 2.5 4 banger automatic Going to replace rear main seal. Can someone tell me what all I need besides the seal, oil pan gasket, oil, filter, transmission fluid, gasket? TIA Click to expand... https://wranglertjforum.com/threads/rear-main-seal-replacement-4-0.826/unread
ScottyZ Member Joined Oct 1, 2018 Messages 98 Location Buffalo, NY Apr 20, 2019 #4 ScottyZ said: https://wranglertjforum.com/threads/rear-main-seal-replacement-4-0.826/unread Click to expand... I see you mentioned that you have a four banger, but shouldn't be much different. Same principals apply.
JayTJ Member Original poster Joined Mar 10, 2019 Messages 31 Location Alabama Apr 20, 2019 #5 ScottyZ said: I see you mentioned that you have a four banger, but shouldn't be much different. Same principals apply. Click to expand... Yessir! I have seen the 4.0 one Reactions: ScottyZ
