So I've been reading forum posts throughout the day, and trying to track down an electrical issue to no avail. I just replaced my radio/head unit, 4 speakers, and added an amp. Since then, Ive been getting a "No Fuse" message that alternatively flashes on my dash where the mileage is. Everything seems to work just fine with the exception of my dome lights. I do not have any real electrical knowledge and could use some help tracking diwn the source of the problem....
I have done the following:
* checked all fuses in the engine compartment and behind glove box
* replaced several fuses just to make certain it wasnt a fuse issue.
* disconnected my new radio from the power harness
* disconnected the Amp from power and ground
************* Update **************
I just discovered that my 10 Amp accessory fuse under the hood is actually blown. When I replace it, it immediately blows again. So how do i how about tracing down the short? Could a loose speaker wire from the old sound bar speaker harness cause a short? OR is it more likely to be innthe dash speakers?
Thanks!
Thanks!
