Mazda's next-gen SkyActiv engines will drop spark plugs in favor of high compression
Chris
Administrator
Staff Member
Gillette, WY
If this ends up working out for Mazda, it will be a big advancement as far as autos are concerned:
Homogeneous charge compression ignition, or HCCI, is the black art of of internal combustion engines that aims to produce diesel-like fuel efficiency for the cost of gasoline. Although some of its competitors have developed and subsequently given up on the tech, Mazda confirmed that the next-generation of SkyActiv engines will employ HCCI technology, improving fuel economy by 30 percent and at the same time reducing exhaust emissions.
According to Nikkei, a new SkyActiv family of engines is set to debut under the hood of the next-gen Mazda3 sometime in 2018 before making its way into other vehicles. In simple terms, an engine that uses HCCI burns the air/fuel mix using pressure instead of with spark plugs, just like a diesel. At 14:1, Mazda's gasoline engines already have some of the highest compression ratios out there, but a move to HCCI means cranking up the compression to 18:1.
While the tech sounds relatively straightforward, using HCCI means dealing with a number of side issues. It's one of those "on paper" ideas that compounds problems when put into practice. Heat, revs, and fuel must all be carefully managed as gasoline doesn't burn the same way as diesel. Mazda is mum on details, but the automaker seems confident that the issues have been sorted. If the new engines do indeed make it to market with HCCI, Mazda will have out-engineered GM, Daimler, and Hyundai, all of which have tried and failed to develop HCCI engines in a cost-effective package.
With the market moving towards electrification, it's interesting to see Mazda still focusing so heavily on traditional internal combustion gasoline engines. It's an indication of where they see the market heading for the next few years. Although the automaker has been hesitant to move forward with hybrid and electric powertrains, Nikkei also reports that Mazda will begin mass production of EVs in 2019.
Reactions: UpperMI and StG58
I hope it is successful when it debuts. Additional fuel savings while still being able to use gas would be huge. I'm not on the wave of hybrids yet. Too many question marks on battery life, recharging time and the environmental factor when creating the batteries. People think that just because you use a hybrid you are being green. In order to understand, look at the effort to build hybrid batteries. Lithium mining is terrrible on the environment.
I agree completely. I don't think the battery technology is there yet, and I don't think it will be where I want it to be for another 10-20 years.
Something like this is a great achievement if it actually comes to fruition. A way to squeeze more mpg out an internal combustion engine, while still using gas. I'm looking forward to seeing it in action. Mazda builds some really nice vehicles these days. Most of them rated exceptionally well (i.e. the Mazda CX-5).
Reactions: UpperMI
Imagine going to the dealer and having the conversation "It keep banging and Knocking like a Diesel"...and their response "Um..its supposed to..."
