So I have a cheap Rampage top. Fairly new. About 6 months old. While installing it I made the mistake of removing the foam padding from the cross member. At speed on the freeway it flapped and made ALOT of noise. I replaced the foam with the same size from HD. It stopped the flapping. But I still have a reverberating loud sound at speed. Almost like when you open one car window and not another. And it sounds like air is popping in and out of your cab.
The other thing I did when installing it. Was I placed the front header plastic strip down without folding over once. The one that you screw down along its length? I don't know if that makes sense or not. But I was having trouble getting the top to fit with the plastic strip folded over once. Like I think it's supposed to be installed. Which gave me an inch or so of extra material in the tight-ness of the top as it stretched back onto the frame. I think if I take the top off and add that fold back into the front plastic strip. And rescrew it down. It will tighten the top quite a bit. And I'm hoping help with the sound from the soft top at speed. It's pretty annoying and loud.
Do you think this issue is just from a cheap top? Is this common?
If I can't get rid of it by tightening the front plastic strip up. I'm going to consider getting a Bestop. It's so loud at speed (about 60 mph and up) you have to almost yell to hear each other speak.
