Removed front drive shaft after noticing slight harmonic vibration following recent removal of tc drop and installation of 8 Savvy DA CA's. Got pinion angle dead on on front and with 0.1 on rear and still had slight vibe at 67+mph. Felt minor lateral play in front shaft (2 month old Tom Woods) so I removed it. Vibe mostly subsided. Put shaft back in and it was back. While wiggling the DS I noticed the play is coming from front UV joint on DS. The joint is moving (in and out directionally) inside the bearing cup. Will call TW tomorrow. Also have slight lateral play in front output yoke on tc. Not sure what to do with that
