Greetings, I kept looking for forums that talk about a popping noise when turning the wheel. I’ve only found threads with popping noises past the firewall, track bar popping noises, and lower steering column popping noises.
My 2004 TJ is making a noise just below the actual steering wheel, in a place that’s not exposed. I took a look underneath right where your feet usually are and move the steering wheel and the popping noise is not coming from the lower part of the column near the firewall.
it’s right behind the air bag I suppose. What could it be? Is there any other way to diagnose it other than cranking the steering column? Or has anyone had a similar issue? I’m not familiar with steering columns.
FYI, it pops when I turn the wheel left and right, sometimes it doesn’t pop in the same position. For example if I turn the wheel 90 degrees it may pop twice but if I do it again, it may only pop once or 3 times therefore it is not very consistent but it does pop every single time.
I am attaching a video hopefully it works. I just bought this Jeep and and I am trying to fix this.
Any help is appreciated!
