I have 4:56 gears with 33” tires on my ‘03 Rubi
After the regear , which I have now nearly worked through in therapy , it had a pulsing vibe at 67 mph and up.
At the time , there were a number of deep and complex regear vibe threads , and my whole regear experience was so dramatic, it seemed to chase the vibe was a rabbit hole I didn’t want to go down.
Talking to a friend who is pretty common sense with mechanical things , he said you know , if you pull the shaft and it fixes it , you really need to get the shaft looked at.
Either it got worse or I noticed it more lately , feeling some buzz slightly at 40 and over , so I pulled the front shaft.
Smooth as glass , at all speeds, I mean a different Jeep. Keep in mind it is soundproofed , has a hard top, all terrain tires , the top of the line spicer u joints , and is fairly car like with 50,000 miles .
So I took it to the drive shaft shop yesterday to have it checked ...they called today , said it was out of balance , welded decent size weights to it on both ends.
I put it on tonight ...that fixed it.
Remember , a vibrating shaft can be seen at speed on a lift ...and shops need to run the shaft beyond the speed you plan to drive .
I know this isn’t the universal solution , but it was for me ....and I can’t be the only guy ...drive shaft balance is critical, and we all have 2 spinning if the hubs are stock.
