I tried using my 4wd earlier this morning and it’s not engaging at all since removing my skid plate the other week. Could something have disconnected near the transfer case ? The lever goes smoothly up and down there’s no resistance ...
What are you talking about lol. You think I would drive around without the plate that holds up my transmission?Whoops you're not supposed to be driving around without the skidplate in place, that's what holds the rear of the engine/transmission/transfer case assembly up!! No doubt it's hanging by your tcase shifter and other things not made to hold that much weight. Get that skidplate back in place asap. Even when being worked on/not being driven there should be a jack under the transmission to hold it up.![]()
Well good, glad to read you had reinstalled it. It read like it was still off, which is not uncommon.What are you talking about lol. You think I would drive around without the plate that holds up my transmission?
I removed it gently and slowly while working on my exhaust system lol
it was edited by someone — it wrote 4wd is not engaging. The skid part was put in by someone else...Well, that is what you posted, you never said your R&R'd the plate just that you removed the skid plate.
Hell even the title of the post just said it was removed
Stop making it then. The title stated “4wd not engaging”.I edited the title from "4 wheel drive not engaging" to say "4 wheel drive not engaging after removing skid plate".
I did not however edit the post itself. You are the one that typed "I tried using my 4wd earlier this morning and it’s not engaging at all since removing my skid plate the other week".
You confused us because you should have written: "I tried using my 4wd earlier this morning and it’s not engaging at all since removing and reinstalling my skid plate the other week".
Anyways, this isn't a grammar lesson. I'm simply pointing out that you confused myself and a number of others with your choice (or lack thereof) words.
The solution is the transfer case linkage assembly, I guarantee it.
You tell me lol it’s quite sad at this point if you ask me.Why has this thread gone off the rails?
That's what happens when you can't shift your t-case.Why has this thread gone off the rails?
Stop worrying about how sad this is and go check the linkage and find out where it became disconnected so we can tell you how to fix it. Just in case you didn't pick up on it, you would not be the first or the last to drive around sans skid.You tell me lol it’s quite sad at this point if you ask me.
Sometimes it happens, just check out my title, but we really are here to help you. Don't get discouraged or frustrated. There is no better source for TJ troubleshooting and advice than here. Consider it a little "ribbing and initiation."You tell me lol it’s quite sad at this point if you ask me.
