My 99 TJ has a 2 inch body lift and what I believe is a 3 inch suspension lift. It also has a transfer case drop which I really don't like. My first question is if I can remove the transfer case drop while keeping the body lift. If I can't remove the transfer case drop while keeping the body lift what if I halved the body lift to 1" would I then be able to remove the tc drop? I'm assuming the transfer case drop includes what I think are the extension brackets for the shift linkage. Would I need to remove that bracket if I remove the spacers? Pics attached are pics of the bracket and the spacers between the frame and the skid plate as well as pics of my drive shaft angles.
