I got my bikini top on, it looks real good, it's nice and tight but since there is a good 4" between the roll bars in the very back it just flaps a lot. I was wondering if anyone has made anything to keep this from happening?
Are you talking about and black pipe? I was thinking maybe some conduit or something. Thanks for replying. You don't happen to have any pictures of yours
do you?
I am going to try cutting a $10, 1/2" closed foam camping pad glued to the underside of the top. I hope it will eliminate flapping and reduce the heat coming off the underside of the top on a hot day.
That will work for the center of a regular soft top but I am talking about the very back of a bikini top. If I did use something like that I would have to figure out how to attach the top to it since it is at the very edge
Sorry missed the part about it being the end. I use to wrap the strap and just pull them as tight as I could. I ran a safari top also so that might not help .
Also by tightening up the middle it should help on the ends.
