Being pretty pleased with the steering on my ' 03 , my last few months have been going through the steering on my '06, which has always been a little quirky.
To me , "going through the steering " means everything that can affect steering , all the tie rod ends , unit bearings , axle u joints while I'm in there, control arm bushings and setting the toe, getting the axles parallel and having a good track bar set up.
The TJ has always had a little tendency to drift right, and now that everything is freshened up, it has a consistent right hand pull...it gives you the sense that if that were gone, everything else would be right in the world. In other words , it isn't wandering, darty, rear steering, bump steering or much anything else. But she pulls right.
The ball joints check tight, but a cross caster or lack of caster issue is all I can think of.
It has no brake issues and the tires have 12,000 miles if that.
I'm ready to send it to an alignment shop - before I do, I'd like your opinion on anything I'm overlooking or how to gauge what the shop tells me .
A good example would be ideal alignment numbers.
Thanks , I'd really like to dial this out -
AndyG
AndyG
