I just bought the Gates idler pulley from O'Reilly's . I will install it tonight - I will reply again if I run into any issues. I had a loud screech upon starting that usually stopped after a minute but would occasionally continue. Sometimes I will go a ways and it will begin again. The dude diagnosed that the tension was between the two line (handy indicators - go Jeep!), that maybe a bearing had a spur or gap that occasionally caught, stopping the pulley, and causing the screech. He based that on some belt residue on the pulley along with my descriptions. At $12 with tax, a Gates pulley seemed like a no brainer. Even if it wasn't the bearings, I will have that peace of mind. According to him the tensioner pulley is based on a spring and looked within limits, and no way to adjust that as it is an internal spring. I figure it could be the belt slipping, but probably not since the spring is withing limits. I replaced the belt last year out of precaution as it looked worn and cracked. That leave the idler pulley which looked alright except for the residues. Again, I will add to this if I continue to encounter the issue after I install the new idler pulley.
