Need help identifying leak
Tob
Weimar problems require Weimar solutions
Lake Charles, Louisiana
I've noticed the engine block has been staying wet-looking along the passenger side, and also between the bellhousing and the oil pan - hoping that's not a RMS leak. I'm guessing the leak is really slow because everything feels dry to the touch, just really grimy. Any ideas on where it's coming from?
Deffinetly valve cover, not to. Until it drips from your intake onto your cats and starts smoking. Then it depends how lucky you are and how good you are with a fire extinguisher.
Just went through that. Replaced the valve cover with fel-pro. No more leaks. Not to bad of a job either.
Reactions: wyorob and Tob
It’s really simple to fix! I just did mine a couple of weeks ago. In the pic, that’s the old gasket. Make sure to use a Fel Pro gasket!
Did you also replace the PCV valve and grommets at the same time?
Yes. It’s a lot nicer to do when you can manipulate the valve cover around. Also make sure to spend your time with a razor or something and clean up the top of the cylinder head and the valve cover.
Reactions: Tob
Lol, same! I was able to get it out mostly intact , broke off most of the outer flange and the all of the elbow.
Is the valve that 90* piece that comes off the cover into the intake? And the only parts I need are the valve and 2 grommets, right?
