A while back I was sorting out a driveline vibe after new rear springs, and my drive line guy basically said-
" Make sure your axles are centered -if not, you are introducing another angle into the driveline".
Recently there was a thread on an axle being off center and a lot of posts said not to worry about it.
What the driveline shop said to me seemed to make sense- albeit I know it would not be much angle.
Also, this shop is so experienced with TJs they won't even talk about vibes with their shafts if you have urethane transmission mounts ...and they know exactly what's going on when you tell them how you are set up, as far as angles, and even rear track bar clearance and all the things we deal with...pretty cool. Seems they know every peripheral factor.
What do you guys think about axle center adding another driveline angle?
