1998 SE 2.5L 5spd I’m bringing back from the dead. It’s got 83k on the clock and only 600 of it has been added in the past 10 years according to CARFAX. In other words, a barn find.
As expected, some electrical weirdness I’m sure due in part to dirt, dead leaves, and dead bugs. However I’ve replaced the dash switch, the column MFS, checked all interior and engine bay fuses, and cleaned the connectors at the lamps so I think I’m covering most of my bases.
I get high beams if I hold the turn signal toggle in, and if I roll the dash plunger all the way left I get dome lamp. Prior to replacing the dash switch I could wiggle the OE plunger and get a little life from the markers and brakes. After replacing the column switch I now have no issues at all getting hazards or turn signals.
Here’s what I’m left with: it’s either the harness connector to the dash switch has burnt terminals or something funky has been done with the aftermarket head unit or grille guard lamps.
Any other ideas before I break down and take this to a mechanic? Thanks for your help.
