Okay. I am pretty sure I have the original OEM frame and top. It has the bow connecting straps, and the 2-latch header piece, along with the rear attachments. I am only missing the actual bow connectors and the rear window roll-up straps. So from what I ordered, and have confirmed I have, I think I am good on parts-Thanks.
That being said, I have two questions regarding the bow attachment hardware. Moab shows a picture (in his referenced) of a smooth-sided bracket without the ribs (specs say that's for a 97-02 TJ) where the specs say an 03-06 TJ it should be (see below). Which one? The 03-06 brackets are a heck of a lot more $$$. Also, how do I deal in with the roll bar pad, and cover set-up? After the brackets are installed-The tabs are not going to show through and I don't see any pre-sewn slots in the cover? Seems like if you ordered one of these with a hardtop, to switch to a soft top, you start from scratch.
Thanks for everyone's input. I'm getting to the point I'm almost dangerous!
