So in setting up my keep for flat towing I was looking for an electric vacuum pump to power the brake booster while the engine was off.
During my search I came across this kit:
https://www.jegs.com/i/JEGS/555/631250/10002/-1https://www.speedwaymotors.com/Comp...r-Booster-Master-Cylinder-Disc-Disc,8335.html
Like hydroboost, the kit replaces the vacuum brake booster. The difference is it uses electric, rather than power steering pump pressure, to power.
The kit claims a master cylinder diameter of 1-3/16”, which I suspect would work with most big brake kits, given that the stock TJ cylinder is 15/16”. (The disadvantage of the larger cylinder is that less pressure is available when the brakes are applied without boost.) The kit claims a max PSI of 2000 psi.
According to Vanco PBS, a stock vacuum booster puts out 1000-1100 psi of brake line pressure (assuming dual diaphragm). The Vanco hydroboost kit claims a max pressure of 2400-2700 PSI, with a master cylinder diameter of 1-1/8 for the 1/2-ton and 3/4-ton kits, and 1-5/16 for the 1-ton kits.
So based on that information, the electric booster would be a moderate upgrade over the vacuum booster, but not quite to the level of the hydroboost. It would eliminate the need for a vacuum source for factory brakes and/or a need for power steering pressure for hydroboost.
One distinct advantage there is that the electric booster brakes can be used at any time, even with the engine off and no auxiliary vacuum pump. So unlike hydroboost, it would be useful for flat towing.
A big unknown would be the reliability of the included pump. If that fails or a fuse blows, you have a dozen, maybe a few more, stops before you lose pressure and end up with manual brakes.
Not arguing that this should be used to replace all hydroboost or vacuum brake applications. But it could be an interesting alternative for a few cases.
Thoughts?
Thoughts?
