Is there any adjustment between the clock spring inner rotating part and the steering wheel?
The cancel for the turn signal is not equal, turning in one direction the turn signal cancels with only a small turn of the steering wheel and a lot more is required when turning the other way.
My guess is that the inner part is rotationally positioned by some feature on the steering tube and that the previous owner screwed up when they put the leather steering wheel on and got the wheel out by one spline position and then corrected it on the adjuster from the pitman arm to the tie rod.
