The 4.0 holds 6 quarts, the 2.4 and 2.5 engines hold 4 quarts.Ha the jeep is the easiest vehicle Ive changed oil in! the lift might help though lol. Its fairly simple and it takes exactly 5qts so its not that hard.
Ah seems like I haven’t done one in a whileThe 4.0 holds 6 quarts, the 2.4 and 2.5 engines hold 4 quarts.
But you were very close to all three of their capacities.Ah seems like I haven’t done one in a while
He's all about suspensionYour kidding...right?
On those, its called "OEL"...It's spelled "Earl" !
I got real good at changing the oil in me VW's every 1500 miles.
I thought you just keep filling it with oil until it starts dribbling out the fill hole?The 4.0 holds 6 quarts, the 2.4 and 2.5 engines hold 4 quarts.
That's only if you use a funnel and fill it through that dip stick thingie...I thought you just keep filling it with oil until it starts dribbling out the fill hole?
If I lived in an apartment, I'd have it changed. I mean, where do you even keep the drip pan in an apartment?
That actually might be the case. I’ve wheeled with that guy Nick and he’s a bit taller than me.Me vs Jeremy
I don’t doubt it my friend. I’m just jealous I can’t sit under my jeep with weight on wheelsThat actually might be the case. I’ve wheeled with that guy Nick and he’s a bit taller than me.I’m still dangerous though!
Oh... the 60s.I change my own oil all the time. It's cool as long as you follow this advice I found on the internet.
Hey @Jerry Bransford ,do you use any oil with zinc?t5?It's too easy on a Wrangler not to change it ourselves. I can be done faster than it'd take me drive to one of the local overpriced quick change joints.
You need to tag Jerry to be sure he sees your post. Just put the @ symbol before his name, like this @Jerry Bransford ^^^Hey Jerry,do you use any oil with zinc?t5?
Pretty much all engine oils contain varying amounts of zinc. I personally would not add extra zinc unless I had a high-lift cam etc. on a high performance hot rod engine.Hey @Jerry Bransford ,do you use any oil with zinc?t5?
