My 98 TJ started having a rapid left turn signal a few days ago. At first my left brake light and blinker wouldn’t work. My left tail light/blinker bulb was on with running lights active, but it was super dim. Right side was just fine. I checked all the fuses in the passenger compartment and engine and nothing was blown. I removed the left tail light assembly and checked for any cut wires/corrosion because I live in the rainy side of Washington. Wires and connections looked fine so I reattached it. Then I tried disconnecting the pigtail for the trailer lights but couldn’t unplug it because my aftermarket bumper was in the way. So I checked the fuses again and tried testing the tail light again. Now the running lights work just fine (running lights are the same bulb for the blinkers and brakes). But I still don’t have a left blinker or brake light even though the bulb lights up just fine for running lights. There’s no whine coming from the turn signal switch either and the wires connected to the brake switch look just fine. I don’t have any aftermarket LED lights other than my headlights. When my hazards are on every bulb lights up just fine except for the left taillight/blinker bulb. I plan to borrow a multimeter and see if a signal is coming from the brake switch/turn signal switch but was wondering if anyone has run into this before.
