I found a nice article on the P0441 Engine Code:
https://www.700r4transmissionhq.com/p0441-jeep-wrangler/
Smog is due on the Jeep and I guess that code will fail the test. I have a couple of questions:
1) Does the orientation of the purge valve matter? The photo shows the 'correct' orientation, with the Top straight up. You can see the metal ear where the valve is normally attached, this places the valve almost 90 degrees sideways. Would this cause the error code?
2) Does anyone know how many miles I need to drive after resetting the code? I've seen between 50 and 100. Will the ODB2 reader tell me when it is ready to test?
I plan to vacuum test the valve and see if the solenoid will trigger with 12v applied. IF the valve passes I guess a vacuum leak is the next most common problem. I REALLY don't want to have to run down a vac leak...
