Mopar7014 TJ Enthusiast Joined Feb 18, 2016 Messages 135 Jul 18, 2016 #1 Does anyone know the little screw size that holds the interior door pulls strap on a TJ?
Jerry Bransford Too many arguments and personal attacks, I'm done. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Jul 18, 2016 #2 Per the Mopar parts catalog, it's a M4.2-1.41x13. Your best bet is to just remove one and take it to the hardware store and find a match.
OP Mopar7014 TJ Enthusiast Joined Feb 18, 2016 Messages 135 Jul 18, 2016 #3 Cool, thank you! I lost them in my build project. Tried to order some but no longer available
Jerry Bransford Too many arguments and personal attacks, I'm done. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Jul 18, 2016 #4 Did you try http://www.moparpartsoverstock.com/p/__/SCREW-M42-141x13/6775981/06504617.html or http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=600190&ukey_product=4303965
OP Mopar7014 TJ Enthusiast Joined Feb 18, 2016 Messages 135 Jul 18, 2016 #5 It is showing those as "door panel screws". Would that be the same as the "pull handle screws?"
Jerry Bransford Too many arguments and personal attacks, I'm done. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Jul 18, 2016 #6 They're all M4.2-1.41x13 screws as the Mopar parts manual shows for the pull handle, whatever they're called.
Matt14 Member Supporting Member Joined Oct 31, 2019 Messages 97 Location Buford, GA Sep 11, 2022 #7 I found these at Napa that worked perfectly for me. I also found a U Nut that it screws into that I could not find anywhere. Hope this helps someone else. I look around for a while to find the u nut part. The part numbers: Skrews: 665-1975 U Nuts: 665-2290 Reactions: SSTJ
