My 2000 TJ is at the tranny shop for a 3550 to AX15 swap. The 3550 died when a 3rd gear hard part broke (loud bang!). There is nothing but aftermarket parts for them since NVG closed. New transmission and rebuilt 231 (with slip yoke eliminator) from Novak. Note that the AX15 can use the same transmission mount as the 3550, but uses different threads in the housing - Novak AX15 threads are 7/16x14. The Novak shifter is a long straight stick, so I went with the B&M Sport Shifter, which is designed for the TJ and uses the same knob threads. Bought a new Crown knob and Mopar shift pattern insert. Drilled and tapped one corner of the B&M base 1/8x28 BSP for an ARB breather fitting, to be plumbed to the ARB breather already installed for the transfer case. The Savvy 231 cable shifter will swap over, as will the speedo gear. Have to extend the harness for the reverse lights from the driver side switch on the 3550 to the pax side on the AX15. Will fill the new AX15 with Red Line MT-90 (Red Line MTL greatly extended the life of my 3550).
After installation, we'll measure from the 231 yoke to the rear Dana 44 yoke, top and bottom, and send those measurements to Tom Wood's for a double cardan rear driveshaft. As they advised me, we will then use my adjustable Currie control arms to rotate the rear pumpkin up to make the pinion line up with the shaft.
Since this area will be opened, I also bought a LuK clutch, with National throw out bearing. The flywheel has 207K miles on it and we'll keep it if it looks good. As a backup, I got a LuK flywheel and new bolts - this LuK is advertised to have the correct domed engagement surface for the TJ. I threw in new lower and upper shift boots, too.
