Hey guys I thought I would share this to show off that scanner I got and too see if anyone might have suggestions for me about this error code..
So it all started about a month ago with a p0441 code.. my engine was starting but dying soon after.. turned out my purge valve was upside down, so I flipped it, cleaned my throttle body, idle air control valve, changed my oil, changed my air filter, and threw in a new set of champion iridium plugs.. the code left and the engine started up good and strong for about a week..
Then one morning I noticed a slight delay in my jeeps return to idle speed when I popped into neutral, it jumped up too like 2000 rpms and slowly came back down to about 1000.. it was on my way too work so I kinda just dismissed it.. next day I started it up and the idle dropped right away for a second but didn’t die and regained it self to idle speed.. then the throttle issues started.. as I would drive it would constantly have a hard time finding its idle in between my shifting or popping into neutral.. this seems to only happen when I’m moving.. if I stay parked and rev the engine it will return to idle fine..
It got worse this morning as I went to get some Carl’s Jr. As I drove I noticed even if I stayed in gear, say 4th and I let off the gas the Jeep still was giving throttle and pulling itself along for 4-5 seconds until it realized I was no longer giving it throttle .. then as I pulled into the drive thru It was just staying at 3000 rpms..kind of funny trying to talk when it’s roaring.. it slowly dropped back down to idle once I pulled up too pay.. they parked me and i sat there waiting for my food I revved it too see if it would return to idle and it did just fine.. then on my way home it seemed to return to idle after every shift.. so to an extent it is doing this intermittently
I am wondering if I killed my idle air control valve when I cleaned it? I feel like if I had a vacuum leak it would have this problem all the time. Maybe because it’s kinda intermediate it’s a sensor going bad but at times working properly? Could it be my throttle position sensor? Anyone with experience in this would be appreciated. My code reader says it could be my computer.. I sure hope not haha
today I am too busy to perform a smoke test on my intake but I am going to try to do it tomorrow. I will take some pictures of this diy smoke unit I bought for 150$ to show you if it works or not.. 150$ is a heck of a lot better than 2000$ Napa wanted to sell me one for haha
Here are the code stills from my phone
