But they could be using a kit that had it under the body?
I've been trying to find something that identifies it, so far no luck, Some kind of hydrovac booster for the brakes or clutch??? Or hell it could just be some kind of vacuum pump??? if you look down and to the left you can see 3 lines coming through the firewall so.... Your guess is as good as mine... maybe??
Maybe ? Anyone that monochromatic paints a 59 Chevy Yellow could be doing almost anything , and not in the best way.
Washed the 1948 DeSoto today. Actually the 2nd time in two days. The first attempt was stymied by a burst pipe in my basement and the fiasco that followed that cluster.
We did about 50 easy miles today but the old broad can pick up her skirt and scoot when need be.
Just a bit off track and with bigger motors, the guy in the back of the jeep on #8887 is flying the Mustang and the guy in the front the F15. Not sure what the redhead was flying.
