So I had three issues begin at the same time. 1 no air blown through any vents (checked vacuum line in engine bay no leaks) 2. Air bag light came on 3. Abs light came one
Any help is greatly appreciated
Turned out it was a bad ignition coil and a bad resistor in the ac interesting
Annnnnddddddd.....dumbass award of the day goes to....me.
I was checking electrical from the switch to fuse box to steering wheel, etc. Tore apart the dash and steering wheel, found a nice 16 gage red/black wire electrical taped together. So I thought until I was giving it a check and the damn thing fell apart. Used a butt connector to see if I found issue and damn if it was the solution.
I’m the 6th owner of this Jeep, guess I need to get a little deeper into looking for PO jack jobs. There are about 6 wires electrical taped together with shit connectors. I’ll be spending the weekend soldering and heat shrinking them.
Now to see if I can return that $280 clock spring. HVAC and blower fan are now working, I’ll have to trace that wire in the service manual to see what else it may have been affecting.
Reviving another thread;
Similar issue with me. Recently noticed my airbag light and triple chime after startup.
Went out shortly after started driving.
Appears to be intermittent. Sometimes I get the airbag light, sometimes not.
Today where I am is cold so I tried to turn on the heat. No air coming out.
Then the airbag light went off and the air worked.
Somehow they are associated, electrically.
Initially I was thinking clockspring, but now that the blower motor is part of the equation, I can’t wrap my head around why.
Haven’t dug into electrical diagrams yet…
Did you figure out how these two are linked? Having the same issue and have checked the grounds and wire brushed the one at the passenger speaker and reinstalled and checked for low voltage. Installed a new control unit but did not fix a thing. Only getting the airbag light on and no HVAC, ABS light has never came on.
