Bolts for Savvy crossmember to transmission mount?
rows
just a new guy
Nebraska
Installing my UAM kit today and the hardware bag doesn’t have anything in that looks remotely correct for this. What are the bolts that go through the bushings on the crossmember to the transmission mount? Something particular or will anything the fits the diameter and length be fine?
Reactions: PNW_LJ
I was going to try to get to mine. I can’t get in there. It’s too narrow. I’m pretty sure they are a zinc plated bolt with a 9/16” lock nut. I believe that’s a 3/8” bolt.
Reactions: josb612 and rows
They are supposed to be Grade 8 3/8-24 with a Grade 8 nyloc and enough length to get full thread after the hardened washer on the slotted side of the mount.
Reactions: rows
Flip the mount over so we can see the other side or tell us if it is welded full length where the sides meet the base plate. If they aren't, don't install it until they are. Otherwise, you will likely wind up with this mess.
  • Wow
Reactions: Andy-WhiteTJ
Thanks everyone for helping out with bolts. I’m glad I posted. I guess I’ve got to figure what to do now. Probably just the easy to get it welded up. @mrblaine is there anything I need to know on welding this? Does it just a need a full bead down both sides of the bottom side?
Yep, that will do it.
Reactions: rows
