Its funny you say this
I just thought this the other day watching a guy driving in his F150 with wired earbuds in. I was like…hmmm, he didnt wanna bother upgrading his stereo
He'll keep doing that until a cop notices...
Seems as it would be a lot easier, cheaper, and sound better to get some high end headphones.
I wear earbuds while driving my jeep with no windows or doors. Helps with tinnitus and i can listen to better quality music at speed
I hate it when someone thinks everyone else wants to or even should hear what they're playing too loudly.That would defeat the purpose for me… I want everybody to hear my music!…. Crank it up!
I just got a 99 TJ with no dash speakers. I tossed in the Polk DB462 4x6 inch speakers and was very disappointed to find there was no bass at all
I just finished the DIY baffles as OP describes and it made a HUGE difference in my opinion. see attached images for how I did it. My aluminum flashing material wasn't sticky like OPs, but I was able to bend and cut it to fit it into place and then duct tape it to hold it, and then i used layers of duct tape to fill in the gaps/holes i couldn't fit the aluminum into.
I was debating the DB525 5.25 inch speakers, but looking at Polk's wbesite, they state the db462s reach 50Hz while the db522s only reach 55Hz. While the 522s can handle double the power, so long as I am using the head unit as an amplifier going for the 5.25" polks is a fruitless effort.
https://www.polkaudio.com/en-us/product/car-and-marine-speakers/db462/112447.html
https://www.polkaudio.com/en-us/product/car-and-marine-speakers/db522/112448.html
I read a lot of these posts where people disagree with the DIY baffle. I don't have pro audio or pro car audio experience like other's have mentioned they do here to prove their expertise, but I do have an understanding of physics and how phase cancellation works. The wave fronts in front of the speaker are out of phase with the wave fronts behind the speaker due to the fact the cone moves on direction. Another to way to look at it: when the speaker moves forward, it creates high pressure in front of it and consequently there is low pressure behind it. Since there is nothing blocking the air in front of the speaker from filling the space left by the displaced speaker, it simply fills that area cancelling the difference in air pressure. No air pressure fluctuations means no sound. It's just physics.
Aside from saying the speakers need a baffle because I just did it and it worked, I have another anecdote to offer. In a past life I was a YJ guy. I swapped the stock YJ speakers for the same polk 4x6 speakers i used in this scenario. The YJ speakers mount flush to the back of the dash, and the db462's coaxial tweeter isn't flush. So i used spacers to mount the speakers, leaving a gap around the edge of the speaker basket and the flat dash. I had no bass response at all. Suddenly it occurred to me that it sounded just like speakers that have no baffle or that aren't mounted to anything. The YJ dash being a solid flat piece of metal that stretches across the entire front of the jeep with speakers mounted directly to it acts as a very large baffle. The TJ has no such piece of metal so the speakers have no baffle to bolt to. Jeep used the foam pieces that are placed in front of the speakers to act as baffles but they didn't work very well for me.
I panic ordered a subwoofer thinking that was the only solution, but the DIY baffles actually work very well, and now the sub will be an enhancement rather than the only way to get decent bass. It's not anything astounding, but i can hear the low end perfectly fine even on the highway now. It's tedious to do but its worth it, and I didn't even need to chop out the bracket to make space for 5.25" speakers.
Sooooo I have a question based on your assertionsSince there is nothing blocking the air in front of the speaker from filling the space left by the displaced speaker, it simply fills that area cancelling the difference in air pressure. No air pressure fluctuations means no sound. It's just physics.
Get a soundbar if you don't have one
Wouldnt the large oem speaker grills also cancel out the sound wave being that they block 60%-75% of the surface area just a mere inch or so from ea front woofer??
If I am understanding your assertions, then a most desirable front speaker grill SHOULD be pure mesh screen or open air flow
Just an FYI - .HEIC files are proprietary to Apple and don't display elsewhere...
Thanks, sorry! Passenger side is completely covered. I was working on the Drivers side so you'll see the inside portion isn't covered yet, but I wanted to show how i shaped the metal a little and then taped over it.
