For reasons passing understanding, I attempted to remove (temporarily) the hood latches from the body/fenders. The first nut was a bit seized, but it turned when I cranked on it. I wasn’t so lucky for the second.
Now the bolt sort of spins. What holds the bolt in place, inside the hinge? It sounds like whatever rubber or plastic piece it is holds for a second and then turns.
Can the body-side hinge be disassembled without destroying it? I’m trying to figure out how to hold the bolt in place to remove it or even tighten it again. I’d take either.
