Hey all, need some guidance on tackling this rust on and underneath the battery tray. Reached a point while wiring the rust that it’s hard brown solid metal, can’t seem to be able to take that off with the wire wheels. Is it safe to leave it like that?
What would you recommend doing at this stage, clean as much as possible and apply a rust reformer or primer and paint?
Should I Change tray brackets? Can’t reach with wire wheels in some areas I.e. between the bracket and the plastic box. Removing the bracket would allow me to probably reach a lot of areas with the wire that otherwise I can’t. But I’m not a mechanic and don’t want to push it beyond my capabilities and tools if not required.
The frame is clean but this section underneath the battery must have been exposed to battery fluids or something with POs.
Thanks
Thanks
