Well I figured I would report back.
I have tire clearance! I had to move the shock mount inboard of the lower control arm mount.
I kept trying to make it work between the outer double rings on the axle and the inside of the lower control arm mount, as most of the pictures I have saved show them placed.
I first tried moving it in so it was on the same plane as the outside of the lower control arm mount. Was close, but it wasn’t till I jumped the mount to the inside of the control arm mount that I got clearance I was happy with.
So I have a solid 3/16” of tire clearance between tire and shock body at full articulation, then I I have about 3/8” between shock and poly tower.
Since I cut the one leg off the lower control mount at my attempt to have it on the same plane, once I moved it over to its final resting place I added a little dog leg to the mount to tie it all back together.
So as I often hear mrblaine say, put it where it fits!
