I am working on refurbishing a set of half doors.
The door latch assembly had been removed from the inside of the doors and the exterior door paddles were as well.
Cleaning and lubricating the door latch assembly is easy enough, but the door paddles need more care. Mechanically they are fine. One is a bit stiff and it's obvious there is years of gummed up lube on the paddle mechanism and spring. I want to clean them thoroughly before painting and lubing.
What is the best solvent to degrease the paddle mechanism? Likewise, what's the best cleaner for the black outside that won't interfere with painting afterwards? I suck at painting but do know it's all about the prep. Once cleaned I will prime them and paint with SEM Trim Black rattle can.
