No speedometer and check engine code P1692
It is hard to find a dealer/shop with the old DRBIII scanner tools ( these tools were last produced in 2007) to reset P1692 code but a Autel/Zurich Pro scanner tool has the reset function. Just find a shop with one of these tools and they will be able to help you.
P.S. The Zurich Pro tool will also reset the transmission functions on your 42rle trans and do the cam/crank relearn special function which will solve most PO341code problems.
I just picked up a Zurich Pro to reset this. Can’t seem to get it clear. Any tips or tricks for me? I see I can rent a DRBIII as well, thinking that might have been the better option than dropping the coin on the ZP.
Okay, so I have a DRBIII emulator running now. Anyone have any insight on how to actually reprogram the PCM using a DRBIII? Can someone point me to a write up somewhere? Appreciate it guys!
Can you tell me your laptop specs ? Ima have to go buy one because i have a Mac lmfao thank you this is helping me out a lot
I actually can’t. I used a copy of Windows via bootcamp on my Mac. I’m pretty confident any windows based laptop will work.
