toximus I live in my Jeep Supporting Member Joined Mar 29, 2018 Messages 7,577 Location Northern WI Mar 20, 2024 #1 Price 50 Location WI Works. $50 shipped.
Weasellee Jeep idiot Supporting Member Joined Jan 19, 2021 Messages 1,072 Location PV, New York Mar 21, 2024 #2 Is this everything needed but the antenna?
wigsajumper TJ Enthusiast Supporting Member Joined Sep 17, 2017 Messages 356 Location Maine, United States Mar 21, 2024 #3 Weasellee said: Is this everything needed but the antenna? Click to expand... I have the same model. That is the whole system minus the antenna and antenna cable. Probably will need to extend the power lines depending on your setup.
OP toximus I live in my Jeep Supporting Member Joined Mar 29, 2018 Messages 7,577 Location Northern WI Mar 21, 2024 #4 Yup, it's everything except the antenna and antenna cable. I also have the clip for mounting it to the dash. Unless you want it pre-installed: https://wranglertjforum.com/threads/center-bezel-for-dash.77455/ I also have the antenna and antenna cable if you're interested in those.
