Anyone know how to wire Rubi locker pump to non-Rubi?
TuckerMAustin
Yakima, WA
Just installed Rubi rear 44 and need to wire up the pump to my rocker switch. Just don’t know which wires to use from the pump to the switch! I’d also like to wire the indicator sensor to the light on the switch so I know when it’s engaged. Thanks in advance!
Reactions: John Cooper
Cut and cap off the green and pink wire where they tie together. Connect the pair of reds to power and black to ground.
I just wired both my front and rear switches like a regular light switch.
Of course I didn't use the factory switch either.
Pulled a hot from the fuse panel to the switch then to the pump and ground from pump to tub.
Thanks for the reply. I just have it wired to the battery to test the pump and it’s not pumping. It does a soft pump for a millisecond and quits. Bad pump?
Reactions: flyinfish
If the pump isn't connected to anything it should keep running. It's designed to pump until 5 PSI is reached and then shut off.
The way you have the pump wired, I'm wondering if the pressure circuit in the pump will work. Try holding your finger over the port and see if it stops running.
