I recently had a 3” body lift removed from my TJ. It was replaced with a 1” Currie body lift and a +2” springs/shocks. The first immediate problem was the fan impacting the top of the shroud. I was able to oval the holes as a temporary fix, but the clearance is way too close and I still occasionally get some noise. Raising the shroud higher doesn’t seem possible because it impacts to top coolant hose.
All my reading suggests a motor mount lift, but I’m not sure raising the engine would help the situation. In fact, if the body is 1” higher than usual, I’m not sure why the fan is impacting the TOP of the fan shroud. Logically, I’d think it would be impacting the bottom.
Anyone have a good idea where to look to figure out what is going on?
