deadbeat son
It's the circumference of the tire, where the rubber meets the road, which gives the distance traveled per rotation. That doesn't change, even if the tire is flat.
You had it right farther up, with suggesting the manufacturer's revolutions per mile figure.
So the rolling circumference doesn't change when the tire is completely flat? Please explain how that is possible. The rolling circumference is a function of the static radius from ground to center of hub. Any other dimension is irrelevant. The manufacturer's revolutions per mile is an approximation, but is less precise.
