Pull the cover below the handle gently and see what broke on the lock out....that is likely where the issue is.
Something is out of whack - wish I could see in person
I found something on how to adjust shift cables that seems to have fixed it I haven't had a tj in a while moved on to jk s and decided to go backwards just trying to fix the little things on the lj I just purchased
Yes, the shift cable needs adjustment to fix that problem. Also, you went forward when you went to a LJ. Good call!
