Details -
2006 LJ (non-rubicon) with 42LRE auto. 100500 miles.
Just installed rock krawler 3.5 inch max travel lift to replace 2" budget boost. Rancho 9000XL shocks. The ZJ tie rod upgrade as well.
Lift included adjustable front lower control arms, adjustable rear uppers, rear track bar bracket; adjustable front track bar, front and rear sway bar links, extended brake lines. Maybe some other stuff I may be missing?
Prepping to get it aligned next week.
The issue:
Before this lift; i had a bit of a wobble in the front that is now gone - attribute that to new tie-rod and track-bar.
HOWEVER - now, at around 50mph, I get a bit of a vibration that wasn't really there before. From what I can read online, driveline vibes from pinion angle issues seem to be at all speeds - this is only for a few MPH at around 50. The vibration is in the rear, as I don't feel it at all through the steering.
Would driveline angles being off cause something like this? As I have an LJ, I do not have an SYE as I was hoping to get away without one. Not 100% sure I got the driveline angle correct. I think it's approx. 2 degrees lower (more horizontal) than the driveshaft. The alignment shop I'm taking it to came highly recommended from the guys at completeoffroad.com (local shop with lots of experience but no alignment machine). The other thing is it *may* be tires, but I didn't experience this vibe before the lift.
I pulled the front driveshaft to eliminate that, no change.
Any Thoughts?
The issue:
Any Thoughts?
