New TJ Owner Requesting Assistance With Stereo
JeepTJ406
Montana
Good evening, I'm a new member and first-time Jeep owner. Very happily purchased a 2004. However, the stereo is in desperate need of an update. My TJ does have the factory sub/amp. I'd prefer to remove/delete the sub and amp, as I'm planning some other console mods more applicable to my needs. I'm planning to install a double-din HU with backup camera, and replacing the dash/roll bar speakers. However, I'm finding conflicting info on the factory amp. Does the amp power the dash/roll bar speakers or just the sub? If possible, I'd like to use the factory wiring for the dash/roll bar speakers, but am concerned if I abandon the amp, I'll no longer be able to use the factory speaker wires. Any guidance/advice would be greatly appreciated! Thank you!
Reactions: Head Lice
I’m about 99,9% positively the factory amp ran the center console sub only and the dash and roll bar speakers were pushed by the head unit like all other TJ’s.
There are tons of threads about stereo setups to deal with that anemic piece.
I’ve tried all of them. Nothing works as good as a 5-channel amp pushing the fronts, rears, and a sub. Several use the Soundstream 640D Nano Picasso amp.
Great plan to use a DD head unit.
Service Manual: https://wranglertjforum.com/attachments/2004-tj-service-manual-pdf.14043/
8W-47 is the wiring diagrams for Audio, page 771
As stated, the sub amp uses all four inputs to create the sub signal, but does not amplify the base speakers. The signal is pulled at C202 up in the lower dash, so no issues discoing at the sub.
Reactions: NashvilleTJ
To replace the factory speakers: Front and rear will fit any 5.25". They will need an adapter to connect the factory wiring to the speaker. If you buy your speakers on Crutchfield, they will include the adapters for free.
Some have found 6.5" that will fit in the rear sound bar. Not all 6.5" fit though.
For the oem sub, many have used a 6.5" kicker sub to replace it. Though if you want a 'real' sub, you will need to go with an aftermarket box.
Reactions: TheBoogieman
