Speedo 8-9 mph off
JoeV21
Connecticut
I'm new to the Jeep community and this Forum. I bought this 97 wrangler sport with the 3 speed auto in it.... I know gross an auto.
My main concern is my ODO and Speedo is off, it's about a 8-9mph difference. My my Speedo says 60 I'm really going 68-69. I have already installed a 31 tooth Speedo gear bc there is BFG 32x11.5 on my jeep. Should I jump to instal a 34 tooth? The VSS is clocked in the correct positon for my 31 short gear
Any other advice would be greatly appreciated
Reactions: macleanflood
Is this the chart you're going off of?
Reactions: rouxbicon
Do you have stock 3.07, 3.55, or 3.73 gears?
That's the thing I don’t know, I try to run the VIN build sheet but it's confusing for me lol. I thought I had 3.07 so I put in a 30 tooth, didn't do anything, threw in a 31 tooth to see maybe I had a 3.55 but it's still way off. I know I can count the drive shaft rotations. But I'm being lazy. But that's probably the smart option
There should be a tag on the rear diff stating the gear ratio.
