I swapped my OPDA this morning suspecting it was the source of my squealing/grinding (it wasn’t but that’s another discussion).
So, I disconnected the battery, followed the “align the pin hole” procedure, swapped it, and reassembled everything.
On the test run, engine runs fine, but I’ve got a P0016 code. First thing I’ve done is tried swapping the OEM Crankshaft Position sensor back in instead of the one that came with the crown unit. Code remains.
So, clearly something is out of sync. Before I go through the trouble of pulling serpentine belts and plugs and verifying TDC, is there anything else I can try?
