I've driven it a couple of days now and had no issues. I've noticed the internal lights are nice and bright every time I stop and get out. As bright as when I have it on the charger. This morning, I accidentally over rotated the key again and my radio, fan, and wipers stayed on, but I couldn't pull out the key until I had it in the correct position. It's going to take me a while to learn how far to rotate to off since rotating it all the way was my normal for the last 10 years.
So far, it seems my random parasitic load was simply me leaving the car on accessory when parking it. It makes sense that it happened more on the weekends because I've been working on the Jeep each weekend.
If you can pull your key out on anything except the off position, I'd recommend making a new one or potentially replacing the lock if it's not the key. Most of you have likely driven a Jeep long enough that it's not a big deal, until someone else drives it and drains the battery for you.
